Worked on left and right seats. Glued the foam pieces together for the left seat. Checked the seat for fit and it is about as good as it can be to fit my long legs. Shaped and formed foam for the right seat. Checked fit for Gerry. Added rigid foam to the back of the seat foam for normal sized people to space it forward and added 2 layers of inch thick foam to the rigid foam so Chris could reach the rudder pedals. This arrangement of two layers of seat foam, then 4" of rigid foam, and 2 more inches of seat foam appears to give a possibility of having a seat that will fit people of about 6+ feet height on down to 5' 2". Glued the blue layer of medium foam to the green bottom foam on the bottom on the right seat.
