Louies Web Site
Date:  11-1-2010
Number of Hours:  6.00
Brief Description:  Entry step modification
Finished welding on left side step. Fit both steps to test and make final adjustments for best fit. Drilled 0.187" hole through center of cross tube between steps through bottom of fuselage, through the 3/4" angle added for stiffening the bottom. This is so the cross tube can be bolted to the fuselage bottom for added stiffness of the steps.
