Cut tubing for the left side step. Cut a piece of 1/8" thick 4130 steel to fit inside of the streamline tubing step support. Drilled #A size holes spaced 40mm apart at the thickest part of the tubing. Welded the strengthening piece inside the tubing through the holes. Fabricated the pieces into a step like the right one. Partially welded the pieces together.
