Assembled one wheel, tire/tube, brake, axle. Test mounted it on the landing gear leg. Found that the 5.00x5 brake interfered with the gear leg. Zenith gear construction photos showed a relief cut into the gear leg to give room for the brake caliper. Used Zenith constructiuon DVD, Grove landing gear system instructions, and AC43.13 for direction.
