Installed the left wing. Put pins in the spar bolt holes. Set the left wing fore/aft position for equal length from wing tip to tail on right and left wings. Set wing angle of incidence on left wing to equal right wing. That is, 345mm from top of longeron to top of rear spar. Drilled hole for fastening rear spar to fuselage spar stub. Bolted rear spar in place.
