Brief Description: Right wing top skin replace & rivet test
Put the top skin on and clecoed in position. Positioned leading edge skin and clecoed to the nose ribs. Checked fuel tank positioning and fuel level sender wires. Checked fit of the fuel level sender cover. Prepared aluminum strips joined by A5 rivets. One set with rivets in oversize holes with JB Weld on one rivet and 3M epoxy adhesive on the other rivet. The other aluminum strips riveted with one rivet in correct size holes and the other in oversize holes such as found on the right wing with 3M epoxy adhesive.
