Installed right wing fuel tank. Formed 3/8" aluminum fuel line to connect to fuel tank outlet and lead to the wing root adjacent to the fuel line hole in the fuselage side. Put AN-6 flare fittings on the ends. Fitted grommets on the line and into holes in the ribs. Connected wires to the fuel level sender. Grounded the fuel tank to wing nose rib #3 with braided ground strap. Connected fuel level sender ground to nose rib #2 and ran the main ground wire from Nose rib #2 connection out through grommets to the wing root.
