Brief Description: Top wing skin L angle reinforcement
Cleaned top skin L angle reinforcements and zinc chromated surfaces that will join the L angles to the ribs. Riveted the L angles to the ribs. Cleaned and zinc chromated the top surface of the L angles that will contact the iunder side of the top skin. Began installing nut plates to the cover for the aileron bellcrank access opening. Sized the holes in the aileron bellcrank bushings to fit the AN-3 bolts for the cable ends. Attached the cables to the aileron bellcrank. Oiled the bushings and made sure the bolts were tightened properly to allow rotation within the bushing.
