Louies Web Site
Date:  3-10-2010
Number of Hours:  3.00
Brief Description:  Secure wing wiring
Finished securing wiring in the left wing. Adjusted lengths so there were no excess or tightness. Put connectors on each end of the aileron trim cable where the aileron attaches. Installed a larger grommet for the aileron trim cable so the connectors would pass through the hole. Vacuumed aluminum swarf out of the wing bays. Checked size of grommets for the fuel line from the tank to see if the AN-6 nuts will pass through. Prepared for installation of the fuel tank.
