Measured the length for the left side fuel line to connect the wing tank to the line in the fuselage.
Installed wire connectors on the fuel level sender from the left side tank to the fuselage wiring. Tested operation of both fuel gauge indicators on the Dynon Skyview display. Both work although not calibrated.
Worked on connecting the airspeed pitot and AOA lines from the left wing to the fuselage lines.
