Covered the fuel pressure regulator with duct tape. Layed up several layers of 3 oz. fiberglass cloth and epoxy resin over the tspe covered regulstor.
Fabricated a 1" dia section of copper tubing Y with 3/8" diameter branch. The 1" dia will go into the 1" SCAT tube feeding cool air to the fuel pump enclosure. The 3/8" diameter branch will provide air to the regulator cooling shroud.
