Began installation of the propeller spinner. Measured cutout location for the propeller blades. Cut holes for the blades with 1 1/2" hole saw. Removed metal between the edge of the holes and the edge of the spinner. Refined cutouts to fit the prop blades with about 1/8" clearance. Checked spacing for the front spinner locating plate. Found that the front plate needs to be spaced in front of the prop crush plate by 22mm. I will have to make 22mm spacers to go between the front plate and the crush plate. Longer bolts will have to be used. The other method of mounting the front plate would be to drill and thread holes in the crush plate between the prop mounting holes and bolt the front plate to the crush plate with spacers between.
