Continued work on baffles around the rear and left rear of the engine. Fastened all the sections together into one piece. Cut a 2.5" hole in the baffle above the #4 cyl head. Riveted a stub tube to the baffle at the hole position. The opening is where the SCAT tube will connect to the oil cooler air inlet.
