Louies Web Site
Date:  7-31-2012
Number of Hours:  3.00
Brief Description:  Oil lines
Oriented the 90 degee AN-6 fittings on the oil filter sandwich adapter and the oil cooler so I could connect them with a section of AN-6 braided SS flex line in a U shape. The connectors are too close to connect straight since there isn't enough length between them for the fittings. Fabricated a 3/8" OD solid aluminum tube oil line to connect the pressure oil outlet on the top rear of the engine to the oil fitting at the front bearing. Mounted the Pure Power screen type full flow oil filter.
Oil lines from engine to the oil filter adapter and from sandwich adapter to the oil cooler.
5th bearing oil supply line installed.
