Louies Web Site
Date:  6-28-2012
Number of Hours:  22.00
Brief Description:  Intake system
Installed the intake system tubing. Fabricated a bracket to stabilize the end of the intake tube near the Carburetor. Final mounting of the carburetor, throttle controls, and the mixture control. Fabricated a hot air inlet for carb heat. Connected the hot air source to the hot air inlet on the air box with 2" SCAT. Connected primer solenoid valve to the intake primer nozzle. Connected manifold pressure intake system fitting to the Dynon manifold pressure sensor. Connected the oil pressure fitting on teh engine to the Dynon oil pressure sensor and to the mechanical oil pressure gauge on the instrument panel. Connected 12 volt power wire from the power firewall pass through to the starter solenoid connector.
Primer solenoid valve and oil pressure sensor tube connected
Intake system, carb heat SCAT, and carb heat control
Intake system, starter wiring
