Bored out inner diameter of the distributor housing so the bushings can be pressed in. Pressed in the bushings. Reamed the inner diameter to fit the distributor shaft. Made a spacer for under the cap where the cap is bolted dow. Tried the shaft in the housing with the housing in the rear case. Found that the shaft has too much vertical movement. The shaft will need to have the vertical movement restricted.
