Louies Web Site
Date:  3-30-2012
Number of Hours:  2.60
Brief Description:  Crank position sensor installation guide
Finished making the 0.063" shims for the crank position sensor mount to position the sensor a bit further away from the starter ring gear. Began work on the crank position sensor installation guide. The guide will position the sensor over the center of a trigger wheel tooth for perfect alignment of the sensor mounting blocks.
