Louies Web Site
Date:  3-22-2012
Number of Hours:  3.00
Brief Description:  Skyview and fuse panel
Worked on configuring the Dynon Skyview current readings. Found I had to reverse the current sensor toroid loop. Disconnected the AWG 2 ground wire from the single point ground, reversed the sensor, re-installed the ground wire. Set up the Dynon current measurement configuration for correct current readings. Changed the layout of the screen on the EMS 50% and 100% screens for easier reading.
Fabricated a latch to hold the fuse panel in the "stowed" position. The latch swings down from the side of the glove box. Epoxied a piece of carbon fiber laminate to the glove box side where the latch will be fastened.
Fuse panel latch fastened to the side of the glove box.
