Mounted the relays and terminal strip to the mounting bracket I made yesterday. I wired the relays to the terminal strip using push on crimp terminals. I ran the wing flap +12v power and ground wires from the instrument panel to the relay terminal strip. Connected with push on terminals. Connected the flap control ground wire to the four flap position push button switches.
