Louies Web Site
Date:  12-30-2010
Number of Hours:  6.00
Brief Description:  Ignition system check
Assembled the ignition trigger wheel & sensor simulator. Tested sensor output with scope. Connected the EDIS unit, MegaJolt controller, Coil pack and 6 spark plugs. Connected the laptop with the MegaJolt control program. Tested the system. All seems to work. Possible problem with timing as read on the timing light. The timing appears to change with RPM when it shouldn't. Need to test with another timing light.
