Louies Web Site
Date:  12-1-2010
Number of Hours:  4.00
Brief Description:  Rudder installation
Worked on attaching the rudder. Aligned bolt holes and drilled/reamed to size. Pressed in bronze bushings rather than using the aluminum supports for bearing surface as shown on the plans.
Weighed the fuselage main gear and tail. It was weighed before with wings attached. Now, the weight and balance moment difference with wings on and wings off will permit calculating the weight and CG with wings on when they are not on.
