Frans Web Site
Date:  6-28-2009
Number of Hours:  53.55
Manual Reference:  M3X-55-20-10-0000
Brief Description:  Elevator Construction
6-28-2009 1130-1550 (4.3 hours)
Built jig for elevator and starting construction on Starboard Elevator. Notice the table was turned 180 degrees to accomodate workspace.
6-29-2009 1830-2015 (1.75 hours)
Laid out bottom section, cut and deburred leading edge, getting framework setup. Notice I have chosen not to secure trailing edge with basic rivet technique, but rather form a bend parallel with trailing edge, and riverting inside the elevator. This will have a much cleaner finish once covered, and reduce the edges that can harm the fabric finish. Taking a lot longer, but worth it.
6-30-2009 1815-2045 (2.5 hours)
Fabricatred and attached tubes to TE and LE.
7-1-2009 1915-2015 (2.0 hours)
Port Elevator assembly.
7-2-2009 1615-2030 (4.25 hours)
Completed Port elevator, started Starboard elevator, attaching bottom tubes to LE and TE
7-3-2009 0845-1530 (6.75 hours)
Cut upper tubes for bort Port and Starboard Elevator
7-4-2009 0815-1230 (4.25 hours)
Fabricated gussets and attaching to Starboard Elevator
7-5-2009 9030-1400 (5.5 hours)
Completed both elevators.
7-12-2009 0730-1400 (6.5 hours)
Deburring and sanding both elevators
7-25-2009 0730-1415 (6.75 hours)
Final prep for Alodyne.
7-26-2009 1030-1600 (5.50 hours)
Final prep for Alodyne completed.
7-29-2009 1630-1830 (2.00 hours)
Alodyned and started final assembly.
7-31-2009 1730-1900 (1.5 hours)
Final assembly, completd.
Total hours this page = 53.55
Bottom plane of Elevator
Upper plane of elevator
Complete with side supports and gussets
