8-8-2009 0945-1000 (.25 hours) AFTER CONSULTING WITH KOLB FACTORY IT WAS DISCOVERED THAT AN ERROR IN DRAWING M3X-55-20-10-0000 MISLABELS THE LENGTH AT 49.12". THE CORRECT DIMENSION IS 50.00". TALKED WITH BRIAN AT KOLB, HE APPROVED TRIMMING THE OUTBOARD EDGE OF THE H-STAB TO MATCH ELEVATOR LENGTH OF 49.12" , IF YOU ARE BUILDING A KOLB AND READING THIS CHECK WITH THE FACTORY!
