Frans Web Site
Date: 10-30-2009
Number of Hours: 80.00
Manual Reference: M3X-57-00-111
Brief Description: Wing
10-30-2009 1700-1930 (2.5 hours) Main Spar Sanding and prepping for Alodine
10-31-2009 0815-1230 (4.25 hours) wet sanded and Scotch-brited Port Spar and Alodined inside and out.
11-1-2009 0800-1030 (2.50 hours) Repaired numerous misinstalled rib rivets and sanded / prepped for Alodine.
11-13-2009 1230-1400 (1.5 hours) Pre-punched (10) mounting holes into all ribs.
11-14-2009 0730-1445 (7.25 hours) Built rib #9 support bracket, cut tubes for drag strut, prepped tubes for Alodine
11-15-2009 0715-1145 (4.50 hours) Scotch-brite, washed, cleaned ribs and drag strut for Alodine.
11-15-2009 1430-1700 (2.50 hours) Alumiprep all ribs.
11-20-2009 0715-1215 (5.00 hours) Alodined port wing ribs and drag strut tubes.
11-21-2009 0745-1215 (5.00 hours) Completed Alodine on drag strut, leading edge and trailing edge tubes.
11-22-2009 0800-1230 (4.50 hours) Drilled drag strut holes, drilled drag strut lower plate, Marked placing for ribs on spar.
11-24-2009 1730-2045 (3.25 hours) Removed factory Spar H-brace rivets that popped out when tube was compressed into circular position.. Reinstalled correctly.
11-25-2009 1415-1600 (1.75 hours) Installed ribs temrporarily on spar.
11-26-2009 0700-1130 (4.50 hours) Completed installation of spars and setup proper spacing.
11-27-2009 0715-1330 (6.25 hours) Installed Rib Boot and end rib temporarily with clecoes. Temporarily installed LE and TE tubes and set ribs to properly contact.
11-28-2009 0700-1315 (6.25 hours) Fabricated LE and TE splices. Assembled drag strut temporarily.
12-5-2009 0730-1300 (5.5 hours) Due to tube shape defect, fabricated a second set of drag strut tubes, cleaned and prepped for alodine.
12-6-2009 0745-1100 (3.25 hours) Alodined and installed drag strut.
12-18-2009 1115-1545 (4.50 hours) Drag Strut final fitting and riveting to Root rib - Left Wing
12-19-2009 0730-1315 (5.75 hours) Drag Strut Final Assembly to bottom plate, installed and riverted Strut support to spar.
Clean and Alodine...
Temporary Installation of Ribs
Drag Strut
