Brief Description: 1 - Complete Control Column Reassembly
Found and installed cotter pins on stick clevis bolts. They were a bear to install. I eventually got them tapped in, but I'm wondering if the size called out is too large? Touched up the primer on the F-665 control column pushrod. I’ll let this cure for a few days before reinstalling the column in the fuselage.
