RV-7 Construction Log
Date: 6-15-2014
Number of Hours: 5.40
Brief Description: Center and Forward Fuselage
I started this session by masking off the outside of the center bottom skin where it underlaps the forward bottom skin, so it could be scuffed, cleaned, and primed (photo 1). I also removed the vinyl from the interior edges outside the fuselage, then scuffed, cleaned and primed all three areas. After a couple of days for the primer to cure, this skin will be ready for dimpling and edge rolling.
I then edge deburred, de-vinyled, hole deburred, scuffed, cleaned, and primed both F-770 forward side skins (photos 2 & 3).
Underlapping section of the forward bottom skin masked off for scuffing, cleaning, and priming.
Interior surfaces of the right forward side skin devinyled, deburred, scuffed, cleaned, and primed.
Ditto for the left forward side skin.
Copyright © 2001-2020 Matronics. All Rights Reserved. |
