RV-7 Construction Log
Date:  1-25-2014
Number of Hours:  1.20
Manual Reference:  Ail. Trim Dwg.
Brief Description:  Center Fuselage - Electric Ailron Trim
My new F-7123 aileron trim pivot block came in from Vans yesterday, so I got it drilled (correctly this time), and match drilled it to the bracket. While I was at it, accomplished the bend in the pivot arm, and drilled the steel tube on the pivot arm for its cotter pin. This should be enough fabrication to allow the servo and pivot arm to be final assembled to the seat ribs.
Drilling the bracket.
Pivot arm bend; nailed it on the first try!
Drilling for the cotter pin.
