Andreas's Challenger
Date:  2-5-2007
Number of Hours:  1.50
Brief Description:  Brakes
Installed brake lever on control stick. Ran the control cables to the wheels and check to see how everything went together. Had to drill a slightly larger hole in the bolt holding the end of the control cable as QCU beefed up the cable but did not increase the size of the hole.
