Brief Description: Completed Painting of the Forward Cover, Side Pane
Finished the brown painting on the forward cover to include the small bush work at the junctions of the tan and green small wedges. Also used the small brush to touch up the elevator brown areas so the transitions between the elevator and stabilizer line up. Applied the black paint to the areas marked for that color on the forward cover and the side panels. Set the fuselage side panels and the cockpit ring side pieces aside along the wall. .
