Brief Description: Applied Primer to the Forward Fuselage Cover
Sanded the cowling nose with the orbital sander and 1000 grit sand paper. Worked on two areas on the cowling with the leather hammer and wood backstop to level out small dents. Applied body filler to several low areas and the marks on the bottom back corners of the cowling. Still some more filling work to do.
Laid out the forward fuselage cover and applied a coat of primer to the top of the cover until I ran out of paint. I'll have to acquire some addition primer to finish the painting.
