Brief Description: Applied Sealing Coats to the Sides of the Fuselage
Used the last of the Stewarts" primer/sealer on the bottom of the fuselage covering up light areas and the spots where the sealer was removed during the finish sanding. Mixed up a quart of sealer using one part fabric glue and three parts water. Bushed on a coat of sealer on each side of the fuselage. Using the small iron to secure several edges of the tapes and iron them in place.
