Brief Description: Painting Primer on Fuselage Bottom and Top
Rolled a coat of primer on the bottom of the fuselage. Left it to dry. Washed the top of the fuselage with the Steward Systems cleaner and rinsed it with clear water on a rag. Applied a coat of primer to the top with a roller. Applied a second coat of primer to the bottom using a paint brush. Washed both sides of the fuselage with the cleaner and followed up with a rinse with clear water on a rag. Applied a third coat of primer to the bottom of the fuselage. Painted the wing stubs with primer. Bushed on the final coat of primer to the bottom of the fuselage. The sides will have to be painted with a coat of light brown paint due to the exhaustion of the primer.
