LARRY'S WEB SITE
Date:  10-29-2018
Number of Hours:  4.00
Brief Description:  Completed Camouflage Painting of Lower Left Wing
Applied a second coat of green paint to those areas on the wing. Selected and applied black paint to appropriate areas on the wing to complete the camouflage pattern on the wing. Rechecked the camouflage paints and touched up any areas where the paint was thin. Temporally installed the aileron on the wing. Matched the wing camouflage pattern onto the aileron for the olive, green and black paints. Allowed the aileron's paint to dry.
Removed the aileron and set it aside. Turned the wing over and wiped the dust from the outer wing section. Wiped that area down with denatured alcohol to remove any oils fron the surface. Laid out the insignia and cut a 1 1/4 inch slit at the end of the control cable fairing. Taped the insignia in place with masking tape. Removed the backing from the front half of the insignia and smooth it out onto the wing. Will need a heat gun to work on the second half of the insignia to form it over the control cable fairing. End of day.
Bottom of Lower Left Wing
