Brief Description: Completed Camo Paint on Top Left Wing
Completed the painting of the green color on the top of the left wing. Added the black paint for highlights on the wing and aileron.
Using butcher paper, marked out the outline of each of the landing light openings on the wing stubs. On the right outline cut the paper 1/2 inch outside of the marked area to form a paper template for marking of the lens. Used a black sharpie to mark the template outline onto the lens blank. Used a Dremel tool with a diamond blade to cut the lens from the blank. Checked the fit of the lens in the opening and it appeared to fit ok. End of day.
