Brief Description: Final Taping on Outer Wheel Cover
Located the position for the addition of the AOA instrument to the panel. Marked the center of the position and drilled a 5/8 inch hole there. Used the 2 1/4 inch hole punch and cut the hole.
Carefully removed the masking tape from the star from both wheel covers. Applied new masking tape around the star for the black edging strip. Completed the taping of one outer wheel cover leaving the other for the next work day.
