Brief Description: Finished Star on Outer Wheel Covers
Carefully removed the masking tape around the red area on the wheel covers. Marked off a 3/8 inch border around each of the points of the star. Taped up each of the wheel covers on the marks around the points. Painted around each of the points with the three colors to form a camouflaged pattern on the outer wheel covers. Set them aside to dry until tomorrow.
Marked off the line for the circuit breakers on the back of the instrument panel on the right side. Marked the line at 1/2 inch intervals and center punched the line on 1 inch intervals. Drilled each hole for a circuit breaker on the center punched point using a step drill. Installed two 30 amp breakers in the first two holes for the right and left ignition power. Install a 20 amp circuit breaker for the alternator warning light in the third position. Installed a 7 1/2 amp circuit breaker for the electric fuel pump in the fourth position. The fifth position is for the scavenge pump and is a 15 amp circuit breaker. The last position is a 10 amp circuit breaker for the avionics power. The stand alone breaker on the top of the second row is a 10 amp breaker for the aircraft lighting. Any additional breakers will be added to the second row.
