Brief Description: Continuing the Painting of the Wheel Covers
Cleaned up the inter wheel covers from the paint removal process by wiping down with a wet rag. Set aside to dry. Removed the edging tape for the white points on the outer wheel covers. Applied new edging tape for the blue points on both of the outer wheel covers.
Painted both the inside and outside of the inter wheel covers with self-etching aluminum primer. Set them aside to dry. Applied a coat of blue paint to the marked points in each of the outer wheel covers. Left them to dry.
Applied the camouflage paint to the inter wheel cover for the tan and brown paint. Allowed the paint to dry to the touch. Applied tan and brown paint to the second inter wheel cover and set it aside to dry. Applied the green paint to the first wheel cover and left to dry. Cleaned up the brushes and stir sticks. Checked the green paint on the wheel cover and found it dry to the touch then added the black to the cover to complete it. The second inter wheel cover will be completed during the next work day.
