Brief Description: Second Coat of Tan Paint on the Upper Left Wing
Went over the top of the wing with the 3M polishing pad to smooth out any specks left in the paint. Used the foam sanding block to sand out one seam on the lower right corner of the wing. Touched up the sanded spot with a light coat of tan paint. Rolled on a coat of tan paint section by section around the wing taking care to leave an even layer of paint. Allowed the paint to dry and then moved the wing back into the wing rack and moved the wings aside.
