Brief Description: Finish Coat of Tan Paint on the Top of the Upper L
Put two coats of primer on the drain grommet and left it to dry. Turned the wing over so the top of the wing was up. Sanded the top of the wing with a foam sanding block smoothing the edges and removing any high spects. Wiped the wing down with a shop towel to remove the sanding residue. Went over the wing top with a tact rag to remove any traces of the sanding. Touched up any areas on the top of the wing where the primer had been sanded thin with the mini roller followed by tipping with the paint brush. Mixed the can of tan finish paint and rolled on a coat of tan section by section across the wing. Put the excess paint back into the can and cleaned up the paint roller and brushes. The second coat of finish paint will be applied during the next work day.
