Brief Description: Finish Coat of Primer on Bottom of Upper Left Wing
Did a final wipe down on the bottom of the wing with a tact rag. Used the small iron to correct a couple of spots where the fabric was not smooth. Sanded those areas and applied a touch of primer to cover the thin areas. Rolled and tipped a coat of primer across the bottom of the wing completing each section before the paint dried. Realized that I had failed to install a drain grommet on the bottom of the wing when I went to turn it over. Used the small iron to remove the paint and glue from a small spot on the bottom inside corner of the wing. Applied glue to the spot of install and laid the plastic grommet on the glue. Cut a two inch circle of fabric and glued it over the grommet wiping away the excess glue. Left it to dry until the next work day.
