Brief Description: Started Sanding on the Upper Left Wing
Applied a second coat of tan paint to the top of the bottom left wing. After the paint had dried went over the top with the 3M polishing pad to smooth the finish. Moved the bottom wing off of the table and back onto the wing rack. Took the top left wing off of the wing rack and put it on the table with the bottom up. Sanded the bottom of the wing with the foam sanding blocks noting any areas or edges which were not smooth. Used the small iron to iron down any edges or areas which were not smooth. Went back over the ironed areas with the sanding blocks to smooth out any raised areas. Wiped down the bottom of the wing with a shop towel removing the sanding residue. The bottom of the wing is now ready for the final coat of primer during the next work day.
