Brief Description: First Coat of Tan Finish on Bottom Left Wing
Wiped down the bottom of the lower left wing and found a couple of areas which required some addition sanding. Completed the sanding and wiped away the residue. Touched up the bottom with primer on the bare spots. Allowed the spots to dry and then wiped down the bottom of the wing with a tact rag. Applied the last coat of primer to the bottom using incremental steps with the roller and then tipped the paint before it started to dry. Ensured that the bottom of the wing was dry and then turned it over so the top of the wing was up. Sanded the top of the wing with the fine foam sanding blocks. Touched up any areas on the top of the wing were the primer was then. Allowed the touchup to dry and then wiped down the top of the wing with a shop towel. Used a tact rag to do the final wipe down. Applied a coat of tan paint over the top of the wing. Left the wing to dry for application of another coat of finish paint during the next work day.
