Brief Description: Started Sanding the Lower Left Wing Bottom
Rubbed down each of the ailerons, the elevator and horizontal stabilizer with the 3M polishing pad. Corrected several places where the edges were not smooth with the small iron. Touched up a couple of places where corrections were made in both the tan and primer paints. Cleared the table and moved the lower left wing onto the table. Used the foam sanding block to go over the bottom of the wing smoothing out the finish. Inspected the wing surface and ironed out any edges which were not smooth. Wiped down the wing to remove the sanding residue with a shop towel. Wiped the bottom of the wing with a tact rag to ensure a clean surface. The last coat of primer will be applied in the next work day.
