Brief Description: Second Coat of Tan Paint on Ailerons and Center Wi
Sanded the center wing top lightly with the foam sanding blocks. Opened the tan paint can and stirred the paint until will mixed. Poured paint into the roller tray and started the process of rolling on a second coat of paint on the top of the center wing section. Completed to second coat and left the center wing section to dry. Laid out the elevator with the top side up. Lightly sanded the top with the foam sanding block. Applied a second coat of tan paint to the elevator and left it to dry.
Moved the center wing section from the table and placed it against the wall. Moved one of the ailerons to the table and sanded the top surface. Applied a second coat of tan paint to the aileron and pushed it back on the table. Moved another aileron to the table and sanded its top surface. Applied a second coat of tan paint to the top of the aileron and pushed it back on the table. Moved a third aileron to the table. Sanded the top surface lightly and applied a second coat of tan paint. Removed the first aileron from the table and moved the remaining two ailerons back closer to the back side. Added the fourth aileron to the table and sanded the top surface. Applied a second coat of tan paint to the aileron top. Left all to dry and cleaned up the paint and roller for the next work day.
