Brief Description: Finish Paint on Right Half of the Rudder
Wiped down the bottom of the lower right wing with a shop towel to remove the sanding residue. Wiped the bottom of the wing with a tact rag to get any remaining dust off the surface. Rolled and tipped a coat of primer on the bottom of the wing. Turned the wing over and sanded the top surface. Inspected the top of the wing and spot sanded any areas that were not smooth. Touched up any areas where the primer was thin or the glue was showing. Wiped the top with a towel to remove the sanding residue and then with a tact rag to remove the dust.
Taped up the rudder so the white strip will be 8 inches wide on both sides when the painting is done. Mixed the can of blue paint and painted the right side end with blue paint. Allowed the paint to dry to the touch and then painted a second coat with a foam brush. Mixed the can of red paint and painted the right side end of the rudder red. Allowed the paint to dry to the touch and then rolled and tipped a second coat of red paint. Applied a third coat of red paint by rolling and tipped application. Allowed the rudder to dry till the next work day.
Closed up the red and blue paint cans. Washed the foam brushes and the roller in water to clean them. End of day.
