Brief Description: Sanding on the Lower Right Wing
Inspected the top of the lower right wing and sanded any area which needed smoothing. Open the can of primer and stirred the paint consistent. Touch up any areas that the primer was thin or the glue was showing. Turned the wing over and sanded the bottom. Used the small iron to smooth down any areas where the tape edges were not smooth. The bottom of the wing is not ready for another coat of primer.
