Brief Description: Sanding on the Rudder and Lower Right Wing
Sanded the white strap on the rudder with the gray 3M pad. Rolled and tipped a coat of white paint on the rudder. Let dry to the touch and then applied a second coat of white paint by rolling and tipped the coat. Set the rudder aside to dry.
Moved the lower right wing onto the table with the top up. Used the foam sanding block and the gray 3M sanding pad to go over the top of the wing. Going to touch up the primer on the top of the wing before turning it over to sand the bottom during the next work day.
