Brief Description: Start of Finish Painting on the Rudder
Remove the center wing section from the table and set it aside. Put the rudder on the table and sanded the white strip on each side. Wiped the sanded surface with a shop towel. Applied a coat of white paint with a mini roller and tipped the paint with a foam brush. Allowed the paint to dry to the touch and then applied a second coat with the roller and tipped with a foam brush. Again waited to until the paint was dry to the touch and applied another coat with the roller and tipped with a foam brush. End of day.
