Brief Description: Finished Primer Painting on the Lower Left Wing
Sanded the bottom of the lower left wing. Used the small iron to smooth down any edges that didn't sand smooth. Mixed up the primer well and touched up the bottom of the wing with a foam brush. Poured same primer into the roller pan and dipped the roller. Rolled one section of the wing and followed with a brush to get a smooth coat. Worked around the wing using the roll and tip process to complete the painting.
Got Paul to help transfer the wing from the table to the stand and secured it in place.
