Brief Description: Applied Third Coat of Primer on Bottom of Lower Ri
Sanded the bottom of the lower right wing with a fine grit sanding foam block. Sanded the inside of each of the inspections ports to smooth the opening. Applied a small piece of fabric tape near the wing tip to cover a weak area over the wing tip brace. Wiped down the bottom of the wing to remove any loose material from the sanding. Rolled on a coat of primer in one section of the wing. Tipped the section with a paint brush. Repeated the process section by section around the wing until finished. Primer painting on the wing is finished at this time.
